Home > In Car Electronics (L322) > CTEK and GAPiiD
Weegie
CTEK and GAPiiD
Don't know whether this is the right place. If not can you move it please, Stan?
I have an e-mail in to GAP but thought I would ask on here whilst waiting. When doing the Nav On the Move update, for instance, the information is to use a battery maintainer as it takes 70 odd minutes to do but not a battery charger .
My query is does the CTEK MXS 7.0 fulfill this function? Anyone know?
Ta. John
GAP iiD BT-Sold
Post #305266 15th Jan 2015 1:30pm
Martin
Site Admin
You need a charger with a "supply" function - the manual for the MXS 7.0 will tell you if it has this (off the top of my head it doesn't)
Post #305269 15th Jan 2015 1:51pm
Weegie
Thanks for that, Martin. Will have a look. Thumbs Up John
GAP iiD BT-Sold
Post #305270 15th Jan 2015 2:02pm
Weegie
Martin, From the CTEK website for the MXS7.0 " It also has a power supply mode which allows the battery to be disconnected from the vehicle without losing important configurations. " Would that cover the requirement? John
GAP iiD BT-Sold
Post #305272 15th Jan 2015 2:07pm
The MXS 7 has a "supply" setting that gives a constant 13.6V output for use as a "float maintenance charging function" or as a simple 13.6V power source.
Post #305275 15th Jan 2015 2:29pm
Mikey
The 7 will be fine, providing your battery is fully charged, and in good condition to begin with Thumbs Up
GAP do say that the whole process can be done without any battery support, if done step by step Thumbs Up
Post #305347 15th Jan 2015 8:10pm
Weegie
Thanks for the replies. I have ordered an MXS7.0 as I needed an up to date charger anyway John
GAP iiD BT-Sold
Post #305348 15th Jan 2015 8:12pm
mjdronfield
I have the ctek 7 charger and an IID tool. Why does it take 70 mins ? Admittedly I have Navcoder and it takes less than 10 seconds to select the option and send to unit.
Don't mean to detract from the great tool that gap have developed..... Am I misunderstanding it ? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #305589 16th Jan 2015 6:58pm
Mikey
It takes 70 minutes to re-write the firmware to the Nav screen Thumbs Up
Post #305632 16th Jan 2015 8:48pm
mjdronfield
So it's a firmware upgrade rather than just a setting change ?
Follow now..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #305645 16th Jan 2015 9:34pm
Mikey
There is a CCF edit, which takes around 30 seconds, then 2 large firmware updates, at around 35 minutes each Thumbs Up
Nav on the Move won't work without the later firmware (and a later discs)
Post #305750 17th Jan 2015 10:23am
