Home > In Car Electronics (L322) > radio not working
cowman
United Kingdom 2005 Range Rover Vogue SE Td6 Adriatic Blue
radio not working
started car up today the head unit lights up with landrover logo no radio ,no tv and no sat nav ,if i press the on /off button it wont switch off, has anyone had this trouble ,is it a simple fix.
Post #305920 17th Jan 2015 7:55pm
battery? ... - .- -.
Post #305925 17th Jan 2015 8:31pm
cowman
new varta battery 6 mths ago
Post #305934 17th Jan 2015 8:55pm
maybe this,
http://www.fullfatrr.com/forum/post248527.html#248527 ... - .- -.
Post #305972 17th Jan 2015 11:07pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I've had this a few times and every time it was low voltage.
Once the battery had a blast on the charger it all fired up again.
Post #305982 17th Jan 2015 11:38pm
We have had a lot of rain sir...You sure your boot seal is not leaking over the BT module or worse sir... Rolling Eyes
Post #305983 17th Jan 2015 11:42pm
Ianmaney
United Kingdom 2011 Range Rover Vogue SE TDV8 Mariana Black
I had this a few months ago, i just pulled all the plugs from the amp, left it for 5 mins and plugged them all back in, worked a treat, burst into life straight away, i also used to have this on me 06 X5 so maybe its an inherent fault ??
Post #305998 18th Jan 2015 7:03am
cowman
thanks for all the advice it is dry in the back ,i will have a look today and let you know.
Post #306022 18th Jan 2015 11:23am
cowman
had a look today did the mod stan suggested and it works radio ,telly and cd player the only thing that doesnt work is the hands free,took the bt apart and there was condensation inside so water has got in ,but not wet anywhere else ,so i need a bt module now at a sensible price ,thanks for all the help spot on .
Post #306346 19th Jan 2015 7:53pm
