![]() | Home > In Car Electronics (L322) > radio not working |
| cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186
started car up today the head unit lights up with landrover logo no radio ,no tv and no sat nav ,if i press the on /off button it wont switch off, has anyone had this trouble ,is it a simple fix. |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35879
battery? ... - .- -.
new varta battery 6 mths ago |
maybe this,
We have had a lot of rain sir...You sure your boot seal is not leaking over the BT module or worse sir... |
| Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118
I had this a few months ago, i just pulled all the plugs from the amp, left it for 5 mins and plugged them all back in, worked a treat, burst into life straight away, i also used to have this on me 06 X5 so maybe its an inherent fault ?? |
thanks for all the advice it is dry in the back ,i will have a look today and let you know. |
had a look today did the mod stan suggested and it works radio ,telly and cd player the only thing that doesnt work is the hands free,took the bt apart and there was condensation inside so water has got in ,but not wet anywhere else ,so i need a bt module now at a sensible price ,thanks for all the help spot on . |
| All times are GMT |
