![]() | Home > Maintenance & Mods (L322) > Towbar Question |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3900 ![]() ![]() ![]() |
Good plan ^^^^^^^ Geoff |
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 348 ![]() ![]() ![]() |
Good plan chaps |
Interesting |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I have never taken a tape measure to my hitch, but I suspect that it is below 18", which is as far as I'm aware the E U standard height that all trailers must conform to. So gotta ask WHY ????????? doesn't make sense to produce a towbar that's below the standard height that all trailers must conform to. I was very disappointed when I first went to hitch up and realised that every |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8008 ![]() ![]() ![]() |
Lesson learned - the hitch with the screw thread may still be available - you would almost certainly find one on eBay - could well be that the dealer had stock to sell..... As long as it's a genuine part, I can't see how it could void the warranty - however, if you weld it, it almost certainly will ![]() It's a shame you're not closer, I would happily swap as I never leave mine on the car, so the bolt is a PITA. |
If you want to go down the bolt route, find yourself a friendly engineering / black smiths place and ask them to tap the hitch that you have to take a bolt, you will have to make the hole in the receiver a bit bigger. But again if you didn't want to tackle this yourself then I'm sure that the people tapping the hitch will take pitty on you.
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
If you are under warranty then there was a service bulletin issued in around 2005 which said that if a customer complains about the rattle then the alternative part with the bolt and threaded armature should be installed. Your dealer should be aware of this but probably isn't. |
Thanks for the replies gents |
