Home > Maintenance & Mods (L322) > Towbar Question
Page 5 of 5 <12345
supershuttle
Good plan ^^^^^^^ Geoff
Post #306665 21st Jan 2015 9:33am
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Good plan chaps Laughing Laughing but seriously though this is is Censored !!!
Post #306670 21st Jan 2015 9:58am
My ifor is a tilt 16ft twin axle. When you tilt it the front wheels lift so, we had a spacer made to go between the chassis and bed so it remains approx an inch tilted (locks are adjustable so still work when adjusted an inch longer)
This one inch tow ball lift allows the trailer to tilt (exaggerated along the trailers length)and levels the trailer when attached to my removable swan necked westfalia tow bar system... And voila! A level trailer Thumbs Up
Post #306672 21st Jan 2015 10:10am
devonchilliman
Interesting Thumbs Up .lets see what I can do Whistle
Post #306763 21st Jan 2015 3:45pm
miggit
I have never taken a tape measure to my hitch, but I suspect that it is below 18", which is as far as I'm aware the E U standard height that all trailers must conform to. So gotta ask WHY ????????? doesn't make sense to produce a towbar that's below the standard height that all trailers must conform to. I was very disappointed when I first went to hitch up and realised that every Censored hole was too near the deck Banging Head Banging Head Normally with L/R it's the other way and the hitch is way too high. Fortunately for L/R the standard is for the trailer and not the tow vehicle, but how could they get it so wrong ? Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #306814 21st Jan 2015 7:19pm
Gibberingidiot wrote:
Wink didn't ignore it,just had to go with the Stealers advice till I got home ,as I was told that would void the warranty Rolling Eyes
Lesson learned - the hitch with the screw thread may still be available - you would almost certainly find one on eBay - could well be that the dealer had stock to sell.....
As long as it's a genuine part, I can't see how it could void the warranty - however, if you weld it, it almost certainly will Big Cry
It's a shame you're not closer, I would happily swap as I never leave mine on the car, so the bolt is a PITA.
Post #306878 21st Jan 2015 9:33pm
miggit
If you want to go down the bolt route, find yourself a friendly engineering / black smiths place and ask them to tap the hitch that you have to take a bolt, you will have to make the hole in the receiver a bit bigger. But again if you didn't want to tackle this yourself then I'm sure that the people tapping the hitch will take pitty on you.
FYI you will need a high tensile bolt, a 10.8 will suffice, and it will need a Nyloc locking nut as well. Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #306937 21st Jan 2015 11:51pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
If you are under warranty then there was a service bulletin issued in around 2005 which said that if a customer complains about the rattle then the alternative part with the bolt and threaded armature should be installed. Your dealer should be aware of this but probably isn't.
Post #306966 22nd Jan 2015 9:02am
devonchilliman
Thanks for the replies gents Thumbs Up
Post #307188 22nd Jan 2015 9:28pm
Page 5 of 5 <12345
