![]() | Home > Technical (L322) > Help!! No reverse!! I'm on holiday....will I drive FF home?? |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883
i googled ''rectal iirigator'' and went to images but although it showed pics of the units it also showed the actual process |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
Thanks for doing the research for us Stan. |
| SKOT Member Since: 24 Oct 2012 Location: Milton Keynes Posts: 792
So you need to top up the automatic gearbox fluid on your Range Rover do you, Sir?
| Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 169
Knew I would trigger some of you with such an ingenious technical device |
Bloody infuriating some of these courier companies! |
Looking at the title of my post.... |
Sorry to hear that fella... Had hoped all would have been well... |
| DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425
Had I read this before I could have beaten tnt, drove down to Colfosco (sat) via Kiens on Friday..... |
@Cam-tech-craig; thanks for your support |
Sorry to read about your woes. |
new valve body incl Sonnax upgrade is also on my list. I assume when TC and valve body are replaced and (if needed) the gearbox is checked and where needed repaired I might have a very reliable drivetrain |
| Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912
Must be 2005 Cairns Blue TD6's that dont like going abroard!
nice colour, bad gearbox |
| All times are GMT |
