Home > Maintenance & Mods (L322) > Puddle Lights
Andy B
Puddle Lights
http://www.fullfatrr.com/forum/topic12599....dle+lights
Fitted the 'Land Rover, Range Rover' Puddle Lights. Got from Supertweaks (£40). Point to note, they mark them (L) Left and (R) Right, but installing them like this means the logo is upside down! So switched over and all is good Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #307222 22nd Jan 2015 10:25pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
They are not really handed .... you can rotate the logo - FYI Smile Mine are set so the LR/RR logo is straight when you open the door to the first natural 'lock' Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #307226 22nd Jan 2015 10:32pm
Andy B
Cool thanks, I can have fun fiddling with the the angles Thumbs Up SDV8 AB MY 2019
Post #307227 22nd Jan 2015 10:37pm
DMRR
It's quite easy to spot, there is a lug on the projector that rotates the logo Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #307228 22nd Jan 2015 10:42pm
I got these and fitted the other day. Shows how well made they are that when I open the door, the DAB signal all but disappears! Shocked Got - 2017 SDV8 Autobiography in Loire Blue
Post #307247 22nd Jan 2015 11:35pm
DMRR
Be warned BTW ... I am on set number two (albeit in 18 months) as some NUMPTY left my door open for eons while it was being serviced. Burnt out the logos Sad
As for 'noise' ... can't pick anything up at all with my cheap chinese DAB? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #307248 22nd Jan 2015 11:38pm
^ even with the door closed? Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #307263 23rd Jan 2015 12:05am
DMRR
Er...with the doors closed the lights are off unless your wiring is totally screwed .... are you sure it's two LED lamps that are messing with your DAB????? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #307265 23rd Jan 2015 12:08am
Sorry, you've lost me now. Until I fitted the new puddle lights my DAB was working well. Now, when I open the door, the DAB signal goes completely and when I close the door the signal is restored.
Clearly there's interference from the new puddle lights. Got - 2017 SDV8 Autobiography in Loire Blue
Post #307269 23rd Jan 2015 12:11am
DMRR
Most baffling, the unit (I have fitted) is simply a bright CREE with a Vinyl(?) print in front of the lens - the entire vehicle has LED's/CREE's fitted to replace the standard lamps (only the D1S lamps are original). As it's a 30 second job to pop out the lamps, remove one and see if the DAB blanks, then replace with your standard one and see if that makes any odds (which it shouldn't)..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #307272 23rd Jan 2015 12:18am
DMRR
...hang on why would you open the door with the engine on.... Shocked Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #307273 23rd Jan 2015 12:20am
I was checking them out Got - 2017 SDV8 Autobiography in Loire Blue
Post #307275 23rd Jan 2015 12:21am
DMRR
Rolling with laughter hehe .... as I said, not sure what the heck could cause the problem as they are not CANBUS lamps, therefore it's simply a CREE with vinyl..... Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #307276 23rd Jan 2015 12:23am
The "normal" lights have no effect on the DAB signal. Got - 2017 SDV8 Autobiography in Loire Blue
Post #307277 23rd Jan 2015 12:23am
I suspect it's some form of RF interference. Got - 2017 SDV8 Autobiography in Loire Blue
Post #307278 23rd Jan 2015 12:24am
