![]() | Home > Maintenance & Mods (L322) > Puddle Lights |
| Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223
http://www.fullfatrr.com/forum/topic12599....dle+lights
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
They are not really handed .... you can rotate the logo - FYI |
It's quite easy to spot, there is a lug on the projector that rotates the logo |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6839
I got these and fitted the other day. Shows how well made they are that when I open the door, the DAB signal all but disappears! |
Be warned BTW ... I am on set number two (albeit in 18 months) as some NUMPTY left my door open for eons while it was being serviced. Burnt out the logos |
^ even with the door closed? |
Er...with the doors closed the lights are off unless your wiring is totally screwed .... are you sure it's two LED lamps that are messing with your DAB????? Land Rover Addict
Sorry, you've lost me now. Until I fitted the new puddle lights my DAB was working well. Now, when I open the door, the DAB signal goes completely and when I close the door the signal is restored.
Most baffling, the unit (I have fitted) is simply a bright CREE with a Vinyl(?) print in front of the lens - the entire vehicle has LED's/CREE's fitted to replace the standard lamps (only the D1S lamps are original). As it's a 30 second job to pop out the lamps, remove one and see if the DAB blanks, then replace with your standard one and see if that makes any odds (which it shouldn't)..... Land Rover Addict
...hang on why would you open the door with the engine on.... |
I was checking them out Got - 2017 SDV8 Autobiography in Loire Blue
The "normal" lights have no effect on the DAB signal. Got - 2017 SDV8 Autobiography in Loire Blue
I suspect it's some form of RF interference. Got - 2017 SDV8 Autobiography in Loire Blue
| All times are GMT |
