![]() | Home > Maintenance & Mods (L322) > strange non starting issue this morning |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Hi chaps,
Left a light on overnight? Try charging the battery and try again? Starter motor? |
Loose earth connection terminal |
many thanks for the replies guys,
Hi chaps, just a quick update,
It sounds like you could be on to something with the gear lever mechanism. Suggest to get back to the outfit that installed it and let them sort out the mechanism first, make sure it is sitting properly and check the connector to the switch before replacing the switch. MY 2010 5.0 SC Galway green and sand interior!!
