![]() | Home > Maintenance & Mods (L322) > strange non starting issue this morning |
| jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259
Hi chaps,
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Left a light on overnight? Try charging the battery and try again? Starter motor? |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
Loose earth connection terminal |
many thanks for the replies guys,
Hi chaps, just a quick update,
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
It sounds like you could be on to something with the gear lever mechanism. Suggest to get back to the outfit that installed it and let them sort out the mechanism first, make sure it is sitting properly and check the connector to the switch before replacing the switch. MY 2010 5.0 SC Galway green and sand interior!!
