Home > Technical (L322) > Engine cranking not starting
William97841
Anyone help....got 3.0td6 starts with easy start 5bar on rail,secondary pump brand new with all new filters and new glow plugs. Once running from cold it just conked out hard restarting but did start, left for 5mins....it won't start crank over fine until the battery dies,great lol. Any help???
Post #307930 25th Jan 2015 8:06pm
I can't be much help but 5 bar is about 995 bar out to make a common rail diesel work, is that the pressure in the rail or just going in to it ? 2008 MY Supercharged
Post #308027 26th Jan 2015 2:52am
William97841
Yh sorry that's the pressure at going into the rail. I'll try again just to double check but I'm no mechanic but it sound like something electrical although I could be well wrong lol
Post #308125 26th Jan 2015 1:04pm
William97841
Right so far I've got someone to put on a textbook t4 only found small problems nothing from the engine but did a leak off test and found one injector leaking back gotta change that now will keep updated
Post #308454 27th Jan 2015 11:57am
Had one injector go on my e39, turned it into a Censored to start. There is nothing that can't be fixed with a hammer😜😜
Post #308577 27th Jan 2015 8:49pm
On the wiki
http://www.fullfatrr.com/forum/topic25398.html
Thumbs Up .
Post #308604 27th Jan 2015 9:56pm
William97841
Cheers for you replies and now changed the injector with the cam and crank sensors still no joy but I did read about a pressure regulator seal oring that goes. So I'm gonna try and replace that as it sounds like it's sucking in air on the regulator. But I'll keep u updated
Post #308874 28th Jan 2015 11:41pm
William97841
So now the car still ain't working. One injector changed, little green seal on fuel pressure regulator changed and new filter and secondary pump. Had the textbook on it they said problem with cruise control and he did say the fuel filter sensor but he cleared them codes and still does not start just cranks. All pressures are good as the textbook stated it.
Post #309617 1st Feb 2015 11:29am
William97841
Well we good news we have started with 2 recon injectors number 1 and 6 and starting n the button great news lol. Although still one problem. While on tick over it just cuts out but starts right up right away again any clues??
Post #311379 7th Feb 2015 4:20pm
ebajema
Maybe still some air left in the fuel system ?? Or a small leak that bleeds the fuel while sitting still and on the second start that is filled up. Small leak on a non return valve in the system, allowing the fuel system to bleed into the tank ??? MY 2010 5.0 SC Galway green and sand interior!!
Post #311468 8th Feb 2015 7:10am
William97841
Well I spoke to soon took the car out for a spin ran for about 20mins then just cut power all to the engine pulled tried to restart would not start. But I tested for power from Earth to the red cable behind battery that runs into the ecu and only got 0.722v when ignition on?? But ignition off and I get 11.72v very weird. Any one?
Post #311478 8th Feb 2015 10:01am
William97841
Hi na I think I have got a dodgy lead or ecu I think. Can I just get another ecu and swap them or they gotta be programmed?
Post #311479 8th Feb 2015 10:02am
William97841
Further update found the battery to have only 20% so gonna change that and see how it goes
Post #312148 11th Feb 2015 2:57pm
William97841
Another lose changed battery car started as it should then after 1hr rangie turns off with all lights on, turn the key off and on and it restarts After the 3rd time in 2hrs says its low down to 11.3volts. Any help would be appreciated thanks
Post #312258 12th Feb 2015 7:29am
ebajema
I'm starting to lean towards the alternator not working properly or at all so the battery is being drained instead of charged. If you check the voltage with a running enginer, it should be around 14+ Volts or so.
Or you still have cabling issues with the main cables for example (check where the cable goes into the clamp, sometimes corrossion gets in there and eats the wiring awaiy without it being visible) as well sa the connections to the chassis. MY 2010 5.0 SC Galway green and sand interior!!
Post #312259 12th Feb 2015 7:39am
