![]() | Home > Technical (L322) > Trans Failsafe Mode |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044
It’s commonplace with the 5L40-E for re-manufacturers simply to replace the parts that have failed and send it out again in the hope that it will make it out of the warranty period (usually one year) without actually replacing the component that caused the failure in the first place i.e. a worn valve block. The Sonnax kits offer a more permanent fix : http://www.fullfatrr.com/forum/topic27204.html
| aclr8r Member Since: 22 Oct 2013 Location: Norwich, Norfolk Posts: 23
Thanks Phil. The local gearbox company that I'm taking it to said that he will replace the valve block (sonnax) along with a complete teardown and rebuild c/w replacement of a new torque convertor.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
typing with crossed fingers as well here |
Ebajema, hope that your fingers are being for my situation and not that you're in the same?
| mrsamram Member Since: 30 Jan 2015 Location: Mumbai Posts: 5
Hello
@aclr8r, crossed fingers are for your box, mine seems to be behaving very well |
| All times are GMT |
