Home > Maintenance & Mods (L322) > small square clips for lower part rear light lens/two bolts
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
what would be the proper name for the small pronged clip with the squared off part that clips into the lower part of the rear light lens-its like a lower link part-it attaches to the plastic barrel like contraption on the rear inner behind light?
the lights fasten fairly well without them-but i would like to obtain same
also what is the order of fastening the two inner bolts-i removed my light guards and there was a bit of an assortment
i have used an allen key with washer-but i have spacers also...
i know its trivial -but i"d like it correct
Post #308222 26th Jan 2015 5:03pm
Prepros123
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Spire nuts if you mean the metal clips
Post #308363 26th Jan 2015 10:58pm
miggit
Is this the sort of thing your after?
http://www.ebay.co.uk/itm/M6-6MM-THREAD-ZI...1c2c0d916a Yesterday I couldn't spell Engineer... Today I are one!
Post #308367 26th Jan 2015 11:18pm
miggit
If its the Black Peg that slides up and down at the bottom of the light, it is not available as far as I can see. However they are removable, they slide off with a bit of Censored Censored , I suggest that you try an appeal to other members who might have an old broken light, and might be persuaded to take pitty on you Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #308371 26th Jan 2015 11:28pm
tony66
peg
yes=thats it better description than mine-black peg with the square attachment
so its not available then-i was gonna try land rover but thats a pity..
Post #308389 27th Jan 2015 12:23am
miggit
You could try L/R to see if they have changed one, and the broken one's kicking about Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #308400 27th Jan 2015 1:02am
miggit
I may have some good news for you bud Very Happy , I have just sold a rear light on fleabay, and the chap is coming up tonight so that I can fit it......... so there will be a broken one floating about......... If your still in the market and the peg is intact, I might just be your new bestest bud Thumbs Up
I'll update you later. Yesterday I couldn't spell Engineer... Today I are one!
Post #308924 29th Jan 2015 9:56am
tony66
peg
great-thank you Thumbs Up
Post #309024 29th Jan 2015 3:46pm
