![]() | Home > Technical (L322) > Locked out ! |
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Any overhead power lines around?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
it happens, supermarket car parks seem to be a popular place where this occurs.. ... - .- -.
| J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541
Really .....
I think the power lines across the road from me repost my posts in the wrong sections every time also |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Anything which operates on the fob frequency can cause interference and stop the locking signal getting through, I had it once in waitrose car park in Malvern, think it was something to do with the remote trolley collecting machine, as when that had naffed off it unlocked!
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
i hope it wasnt caused by a scanner scammer scrote, sucking in your keyfobs signal, -in a van parked nearby...and storing it for dirty trickery..... could you not have tried putting the key in the slot? you know, like your front door at home...?
| jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259
Duff Battery in the fob?
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
CCTV camera's used to do it to P38's all the time |
If I change the battery just I test that theory does it then need resetting / recoding? |
| sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286
Shell wifi in particular interferes with the lr remotes.
| Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223
No re-coding, just straight replacement. Did mine last week Type is CR2032 SDV8 AB MY 2019 SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
| jarv Member Since: 12 Jun 2013 Location: London Posts: 30
Had some building work done last year. The lorry delivering the materials had a remotely operated crane thing on it. Couldn't get in my car whilst he was delivering, but once he left, everything worked fine. |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Yep, when I worked at AT&T in Redditch our offices were under a water tower with a load of transmitters on it. Just about every car in the car park was left unlocked - nobody's tweeky locking thing worked |
Thanks chaps |
