![]() | Home > Technical (L322) > Locked out ! |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
Any overhead power lines around?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
it happens, supermarket car parks seem to be a popular place where this occurs.. ... - .- -.
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Really .....
I think the power lines across the road from me repost my posts in the wrong sections every time also |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Anything which operates on the fob frequency can cause interference and stop the locking signal getting through, I had it once in waitrose car park in Malvern, think it was something to do with the remote trolley collecting machine, as when that had naffed off it unlocked!
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
i hope it wasnt caused by a scanner scammer scrote, sucking in your keyfobs signal, -in a van parked nearby...and storing it for dirty trickery..... could you not have tried putting the key in the slot? you know, like your front door at home...?
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Duff Battery in the fob?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
CCTV camera's used to do it to P38's all the time |
If I change the battery just I test that theory does it then need resetting / recoding? |
sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286 ![]() ![]() ![]() |
Shell wifi in particular interferes with the lr remotes.
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
No re-coding, just straight replacement. Did mine last week ![]() Type is CR2032 SDV8 AB MY 2019 SDV8 VSE MY 2015 - Gone 5.0 S/C AB MY 2010 - Gone 4.2 S/C VSE MY 2006 - Gone |
jarv Member Since: 12 Jun 2013 Location: London Posts: 30 ![]() ![]() |
Had some building work done last year. The lorry delivering the materials had a remotely operated crane thing on it. Couldn't get in my car whilst he was delivering, but once he left, everything worked fine. |
Yep, when I worked at AT&T in Redditch our offices were under a water tower with a load of transmitters on it. Just about every car in the car park was left unlocked - nobody's tweeky locking thing worked |
Thanks chaps |
