![]() | Home > Maintenance & Mods (L322) > Drivers door lock |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Does this help at all?
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
It certainly does. Thank you for that |
Wish we were allowed to swear on here !! Doorcard off this afternoon, lock removed, ebay replacement fitted and bingo.... nowt. zilch,pooooooh. It didn't work. At least the old one would lock via the fob even if you had to stick the key in the lock to open it.
Dave, a word of caution sir. IF the assembly decides it will fail completely when deadlocked it will be a HUGE P.I.T.A. |
I know, hence I am now trying to source another one. Loads of F/N/S ones but no F/O/S. Message from seller..'Hi, sorry to hear you are having problems with the door catch, why it is no longer working is a bit of a mystery as the catch was taken from a vehicle i had used on a daily basis and worked perfectly up to the very day it was removed which was only a week before you purchased it'
