![]() | Home > Technical (L322) > Suspension Fault - again |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Sounds like a dodgy height sensor to me sir... I presume it will achieve of road height? (so no holes in the bags) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
any electrics on when you cleaned it?...could be a low voltage battery.. ... - .- -.
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Craig - I thought the same initially, so will get it plugged in, quite happy getting to off road height though
Sounds even more like a height sensor now then Nick |
Craig - take your expert guidance on this....so I just tried the car up and down....it goes up and comes down but settles in access left then right...
Yes nick, all very straight forward ![]() |
Oh well that's good news at least. I'll get it checked this week. Currently in normal height and I am not going far ! Is this where I put the car details and a bit about myself ?........ |
its a FF so it will ok tomorrow.. |
Stan....many a true word.... |
Just come out of work....back end on the deck...sat in car park with it running for 3 mins, put in off road height....straight up, then put in normal height...straight to that....then drove home "suspension fault normal ride height only"
check the bag by going to off road height nick and spray some soapy water on the bags and listen/look for leaks... ... - .- -.
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
I had a bag go once but it only really showed up at off road height. The tear was underneath the crease when in normal and access so did;t seem to leak (not so much pressure either I guess) Ash
Been on the ramp tonight, no tears. Reset and fault code cleared. Suspension happy going up and down. See how it goes overnight and then back into garage in the morning if/when it drops.
