Home > Technical (L322) > Suspension Fault - again
n1cktdv8
Last year when it was very cold I had a suspension fault flag up on a few mornings if I hadn't used the car and it had been sat, usually cleared in a few miles after a stop and start !
Yesterday during a milder spot I cleaned the car and had the suspension in off road height. Then back to standard and all was well. The car has previously been sat for a week in access.
This morning, less than one mile into my journey I got "suspension fault normal height only" flag up....
Any basic checks before I get the garage to plug it in.... Is this where I put the car details and a bit about myself ?........
Post #309931 2nd Feb 2015 12:20pm
Sounds like a dodgy height sensor to me sir... I presume it will achieve of road height? (so no holes in the bags)
Post #309933 2nd Feb 2015 12:23pm
any electrics on when you cleaned it?...could be a low voltage battery.. ... - .- -.
Post #309934 2nd Feb 2015 12:23pm
n1cktdv8
Craig - I thought the same initially, so will get it plugged in, quite happy getting to off road height though
Stan - I had a very low battery, car been sat for almost 2 weeks without use, after just 1 year I am considering getting that checked too as it's an S5 so should be superb
I had the car set at off road, all looks level too....but then jetted under the arches.... Rolling Eyes
Only happens in the cold !!
Big Cry Is this where I put the car details and a bit about myself ?........
Post #309938 2nd Feb 2015 12:29pm
Sounds even more like a height sensor now then Nick Whistle Thumbs Up
Post #309940 2nd Feb 2015 12:31pm
n1cktdv8
Craig - take your expert guidance on this....so I just tried the car up and down....it goes up and comes down but settles in access left then right...
Height sensor....bet I have bloody jetted it !!!! Censored
Assume plug in will show which one and then re-programme after its replaced?? Is this where I put the car details and a bit about myself ?........
Post #309941 2nd Feb 2015 12:32pm
Whistle Whistle Whistle oooops Embarassed Embarassed Embarassed
Post #309942 2nd Feb 2015 12:34pm
Yes nick, all very straight forward Thumbs Up
Post #309943 2nd Feb 2015 12:35pm
n1cktdv8
Oh well that's good news at least. I'll get it checked this week. Currently in normal height and I am not going far ! Is this where I put the car details and a bit about myself ?........
Post #309944 2nd Feb 2015 12:36pm
its a FF so it will ok tomorrow.. Mr. Green ... - .- -.
Post #309945 2nd Feb 2015 12:42pm
n1cktdv8
Stan....many a true word.... Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #309956 2nd Feb 2015 1:01pm
n1cktdv8
Just come out of work....back end on the deck...sat in car park with it running for 3 mins, put in off road height....straight up, then put in normal height...straight to that....then drove home "suspension fault normal ride height only"
Is it a bag ? Is this where I put the car details and a bit about myself ?........
Post #309990 2nd Feb 2015 4:33pm
check the bag by going to off road height nick and spray some soapy water on the bags and listen/look for leaks... ... - .- -.
Post #309996 2nd Feb 2015 5:27pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I had a bag go once but it only really showed up at off road height. The tear was underneath the crease when in normal and access so did;t seem to leak (not so much pressure either I guess) Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #310096 2nd Feb 2015 11:12pm
n1cktdv8
Been on the ramp tonight, no tears. Reset and fault code cleared. Suspension happy going up and down. See how it goes overnight and then back into garage in the morning if/when it drops.
Been 2 hours and no drop so battery voltage maybe ? No suspension fault on dash after a quick 20 mile wander around the roads....
fingers and toes crossed ! Is this where I put the car details and a bit about myself ?........
Post #310111 2nd Feb 2015 11:55pm
