![]() | Home > Technical (L322) > How do the Adaptive light work? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
question craig, if you have a 2010/12 facelift done ,do you loose the AFS? ... - .- -.
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 ![]() ![]() ![]() |
yes that's correct headlamps rise up when switched on ![]() |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
^^ I've been advised that even with facelifted AFS headlights, they don't work on an earlier car Stan. Got - 2017 SDV8 Autobiography in Loire Blue
thanks alan.. |
Take a look here Stan http://www.rangerovers.net/forum/9-range-r...ash-2.html
Just looked at my build list and see this :
if you have that neil then you should have afs according to the WM,
...so mine is either OFF or duff? I must investigate |
Time to check this ..... maybe?
i only ever had one problem with mine and that was after i took the headlight unit out but even then i had an error come up on the dash as i hadnt fully pushed the headlight plug in..
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
I don't think you have AFS headlamps... I think all 06> have electronic levelling but only VSE's and AB's had AFS as standard...
I would have expected an error on the dash if the fuse had one, since the criss-cross light pattern is when the ECU checks the position of the headlights. Got - 2017 SDV8 Autobiography in Loire Blue
Yes Stan, you loose it as 09> Headlamp AFS are LIN BUS pre 09my are CAN BUS and never the twain shall meet! ![]() |
