Home > Technical (L322) > How do the Adaptive light work?
Page 2 of 3 <123>
06-09my you can only have both, cornering & adaptive or nowt!
So, if yours have the cornering bulbs fitted then you should have AFS Thumbs Up
Post #310544 4th Feb 2015 3:43pm
question craig, if you have a 2010/12 facelift done ,do you loose the AFS? ... - .- -.
Post #310548 4th Feb 2015 3:47pm
Swiftman
Scotland 2006 Range Rover Vogue SE Td6 Zermatt Silver
yes that's correct headlamps rise up when switched on Thumbs Up
Post #310555 4th Feb 2015 4:02pm
^^ I've been advised that even with facelifted AFS headlights, they don't work on an earlier car Stan. Got - 2017 SDV8 Autobiography in Loire Blue
Post #310556 4th Feb 2015 4:03pm
thanks alan.. Thumbs Up ... - .- -.
Post #310557 4th Feb 2015 4:08pm
Take a look here Stan http://www.rangerovers.net/forum/9-range-r...ash-2.html
I know talks about the RRS but I think it's the same issue on the FF Got - 2017 SDV8 Autobiography in Loire Blue
Post #310567 4th Feb 2015 4:22pm
it appears theres a comm problem between the old ecu and the newer afs lights.. ... - .- -.
Post #310571 4th Feb 2015 4:34pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Just looked at my build list and see this :
Dynamic Headlamp levelling
....but patently they don't, or is that some other magic? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #310573 4th Feb 2015 4:40pm
if you have that neil then you should have afs according to the WM,
Post #310580 4th Feb 2015 4:52pm
DMRR
...so mine is either OFF or duff? I must investigate Big Cry
It might explain why my lighting seems very biased to about 3 feet in front of me Thumbs Up Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #310582 4th Feb 2015 4:56pm
DMRR
Time to check this ..... maybe?
 Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #310588 4th Feb 2015 5:03pm
i only ever had one problem with mine and that was after i took the headlight unit out but even then i had an error come up on the dash as i hadnt fully pushed the headlight plug in..
curious to know whether you have them or not and why they dont work if you have.. ... - .- -.
Post #310590 4th Feb 2015 5:06pm
I don't think you have AFS headlamps... I think all 06> have electronic levelling but only VSE's and AB's had AFS as standard...
So, my guess is you have a Vogue? Without cornering bulbs?
Post #310592 4th Feb 2015 5:09pm
I would have expected an error on the dash if the fuse had one, since the criss-cross light pattern is when the ECU checks the position of the headlights. Got - 2017 SDV8 Autobiography in Loire Blue
Post #310593 4th Feb 2015 5:10pm
Yes Stan, you loose it as 09> Headlamp AFS are LIN BUS pre 09my are CAN BUS and never the twain shall meet! Bow down
Post #310594 4th Feb 2015 5:11pm
Page 2 of 3 <123>
