![]() | Home > Technical (L322) > HEATED STEERING WHEEL L322 VOGUE |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
yes i will try that, thanks
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8645 ![]() ![]() ![]() |
Not that much for a new wheel....
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
The steering wheel switch is non latching, and if the red light is coming on then the switch is doing its job. But if the light is going out almost instantly, I would surspect the 'ECU' |
Are But Craig its not an ECU it's a bloody slow glow plug timer |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16344 ![]() ![]() ![]() |
Are but its
What your saying is it's a re-named glow plug timer that L/R have marked up to the power of 10 |
Just being facetious Miggit |
Wasn't ignoring bud, just questioning the implied computer control bit, a timer chip is more like a stupid computer sitting in the corner with it's shoes and shocks off, to enable it to count to 20! ECU's to me contain a processor and require mutiple inputs to function, where as we are talking about something that's more like a flasher unit or a wiper delay relay. Relay to me is £5 to £30, ECU is £200 plus, although if JLR are invloved £200 + for a simple relay is not beyond imagination |
Miggit, di you remember the Austin Meastro |
SteveyD Member Since: 11 Dec 2012 Location: Cheshire Posts: 352 ![]() ![]() ![]() |
Sounds like the element has developed a fault. I had the exact same problem. Press the button, red light comes on then goes off. Is a circuit that's constantly monitored by a thermistor used to regulate the temperature, same as the heated seats. The eminent could be fine and the thermistor could be at fault. Regardless no items are serviceable. The wheel change is an easy job although the air bag is fiddly to remove (especially if someone's been at it before)
Craig |
Well my steering wheel ECU must be well broken because mine stays on for as long as the button is pressed, had it on for three hours the other day.... I do like warm fingers....
Mine never self switches off! Once turned on, it stays on until either i turn it off or i finish my journey!
