Home > Maintenance & Mods (L322) > Steering column noise
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
The in and out movement of the steering column has just started to make a louder noise over the last few days when being switched on and off . A search on here came up with the suggestion that if it's not a lubrication problem, a low battery could be to blame. Battery showing 12.13 volts. Also getting the HDC warning every morning which I've had before but which stopped when I last replaced the battery. What volts should a fully charged battery show ?
PS can't find a link I had to a site which showed where to drill a precise hole on the steering column to squirt in some copper grease. Did this two years ago on a mates and completely cured the sticking steering column problem.
Post #311809 9th Feb 2015 8:06pm
DaveK
Found it !!
http://www.blackbox-solutions.com/photos/L322lock.pdf
hwever, my new problem is the motor running slowly rather than the locking pin sticking.
Post #311869 9th Feb 2015 11:12pm
DaveK
Column shroud dismantled and both up and down/ in and out spindles greased but they where pretty well lubricated to begin with. Noise still there when wheel goes in and out though so it sounds like the motor that does this is on it's way out. Is this a replaceable part ?
Post #311968 10th Feb 2015 3:30pm
this any good?
http://www.rangerovers.net/repairdetails/s...troduction ... - .- -.
Post #311994 10th Feb 2015 5:50pm
DaveK
Thank You. Have seen this. My tilt is fine, its the reach motor that is giving me concern. Have seen a dash out job on a FFR before and I am filled with dread at the thought of this just to change a small motor.
Post #312122 11th Feb 2015 12:05pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Its not the white nylon mounting clip the motor sits on starting to work loose is it? My reach stopped working - found the white mount bracket had snapped in two leaving the motor dangling. If yours is still working but noisy, perhaps the mount is starting to weaken and the motor moving on the mount is making it not engage fully with the flexi drive? Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #312252 12th Feb 2015 12:32am
