![]() | Home > Maintenance & Mods (L322) > Steering column noise |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 794 ![]() ![]() ![]() |
Found it !!
Column shroud dismantled and both up and down/ in and out spindles greased but they where pretty well lubricated to begin with. Noise still there when wheel goes in and out though so it sounds like the motor that does this is on it's way out. Is this a replaceable part ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35831 ![]() ![]() |
this any good?
Thank You. Have seen this. My tilt is fine, its the reach motor that is giving me concern. Have seen a dash out job on a FFR before and I am filled with dread at the thought of this just to change a small motor.
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Its not the white nylon mounting clip the motor sits on starting to work loose is it? My reach stopped working - found the white mount bracket had snapped in two leaving the motor dangling. If yours is still working but noisy, perhaps the mount is starting to weaken and the motor moving on the mount is making it not engage fully with the flexi drive? Current Fleet:-
