Home > Maintenance & Mods (L322) > arnotts airbags
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
arnotts airbags
Hi all,
Has anyone replaced there front airbags with the latest airbag from Arnotts.
I think I might have to replace mine sooner rather than later.. Crying or Very sad
cheers
Post #311696 9th Feb 2015 2:00am
Did look at them when I replaced mine a while ago but with shipping to the UK they were far more than the original Delphi's, and they last for years, so can't see the point.... Pete
-Click here for Thread-
Post #311785 9th Feb 2015 4:07pm
Edfors
Sweden 2008 Range Rover Vogue TDV8 Alaska White
Does someone know if the Arnott bags has longer suspension travel? Is there an advantage with them if you want to raise the L322 suspension to higher levels?
Post #311789 9th Feb 2015 5:34pm
It's the shock that controls the maximum and minimum height, not the airbag.
The old struts (bag and shock) fitted to mine, I believe they were Dunlops, had a good couple of inches less travel than the ones I fitted, original Delphi.
You can raise the height by about 3" without issue and this still gives you a few inches drop...
You have to leave some drop or you have no suspension....
Mine with a 3" IID tool lift and 32" tyres gives 19" clearance under the sills which is more than most mildly modified off roaders Pete
Post #311898 10th Feb 2015 9:40am
ebajema
Have a good snoop around the net on the quality of the bags. On this forum it seems that the Dunlop complete struts have a bit of a failure rate with the top bearings and the Delphis don't. If you only replace the bags, that becomes less of an issue of course but still it is worth checking out what is being said about the quality of the Arnotts.
I always have to think Tim Tam when I hear Arnott. For those of you who don't know (you should anyway) Tim Tam is the best cookie/bicky in the world originating in Australia. YUM !! Interesting side note, Tim Tams were born in 1964 same year as me Smile Off Topic MY 2010 5.0 SC Galway green and sand interior!!
Post #311941 10th Feb 2015 12:34pm
littlecub
Hi Ebajema,
When they brought out the tim tams,I wasnt overly keen on them.Even now with all the different flavours that they come in,I'm still not keen on them.
But then I'm not your average aussie. Laughing
Post #312072 11th Feb 2015 3:42am
ebajema
Sorry for you mate, just bought two packets of double coats today. Me and the ladies in this house love 'm Smile
With regards to the bags, I remember looking into them a while back and I can't remember if I read any negative reports. There are some YouTube clips on how to replace them that are quite good.
I decided to go for the full struts as the mileage on my SC was enough for the shocks to also be replaced. MY 2010 5.0 SC Galway green and sand interior!!
Post #312073 11th Feb 2015 6:37am
I thought you had to use Delphi bags on a supercharged because being a different set up the Arnott's are not compatible , as for the biscuits I don't have a sweet tooth so its Arnott pizza flavoured shapes all the way for me Thumbs Up 2008 MY Supercharged
Post #312082 11th Feb 2015 9:28am
littlecub
I've just heard back from the guy I bought it off and he said that he replaced the front with OEM bags,so am pleased with that.
Might be the compressor,altho I would have thought all 4 sides would go down.
I'll check the tubes and connectors and see how they are.
Glad you love em,its what keeps the yankee owners afloat .lol
Post #312083 11th Feb 2015 9:31am
