![]() | Home > Maintenance & Mods (L322) > arnotts airbags |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Did look at them when I replaced mine a while ago but with shipping to the UK they were far more than the original Delphi's, and they last for years, so can't see the point.... Pete
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 ![]() ![]() ![]() |
Does someone know if the Arnott bags has longer suspension travel? Is there an advantage with them if you want to raise the L322 suspension to higher levels? |
It's the shock that controls the maximum and minimum height, not the airbag.
Have a good snoop around the net on the quality of the bags. On this forum it seems that the Dunlop complete struts have a bit of a failure rate with the top bearings and the Delphis don't. If you only replace the bags, that becomes less of an issue of course but still it is worth checking out what is being said about the quality of the Arnotts.
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 327 ![]() ![]() ![]() |
Hi Ebajema,
Sorry for you mate, just bought two packets of double coats today. Me and the ladies in this house love 'm |
I thought you had to use Delphi bags on a supercharged because being a different set up the Arnott's are not compatible , as for the biscuits I don't have a sweet tooth so its Arnott pizza flavoured shapes all the way for me |
I've just heard back from the guy I bought it off and he said that he replaced the front with OEM bags,so am pleased with that.
