![]() | Home > Technical (L322) > IID tool Bluetooth ECU Reflash |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Hello Gents
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
When mine doesn't work, it usually means I left the parking brake on. |
I can get the tool to work fine when not connected to the pc, but as soon as. It is, nothing.
Keep us updated as I want to do the same - how are you dealing with the battery - 40 mins on pos II will drain it...... Land Rover Addict
DMRR...Will do.
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 455 ![]() ![]() |
paulmoran2: I too would be very interested to read how things progress. I want to re-flash my 2005 MY Td6 Bluetooth ECU but am a bit wary of fiddling with things electrical I don’t understand … |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3271 ![]() ![]() ![]() |
Steve, What are you using? If bluetooth iiD and iPad it is astraightforward job reflashing. If you log into the Gap website and look at the documentation it explains that it is a low risk reflash. John
Hi John/Weegie
Steve (bebechoon)
Thanks, Paul. It's good to know that for once I am privileged!
Yes it was you Steve. (I had assumed the mantle of a chum |
I had assumed the mantle of a chum: but oeuf Corse! Pleased to hear it |
No Steve..the reflash couldnt really make that situation any worse could it?...its simply not working for you at all |
I had exactly the same symptoms - hung up when answered. The reflash of the ECU solved it. |
Well...I did manage to do it,
