Home > Technical (L322) > Crimped connector help
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
Hi guys, as posted on other threads I have just swapped my 7 pin towing sockets for a 13 pin socket. The car side is fine but on the van the terminals on the grey socket were completely rusted, so much so that I couldn't get a screw driver in the heads and had to butcher the old plug. This wasn't a problem as I was fitting the new 13pin plug anyway but the heads of the connector screws have sheared so I'm going to have to cut the wires off the old plug.
The problem I have is finding the right crimped connectors to use. Most places only seem to do insulated bullets and spades but theses are not what I need. I think I need un insulated pin connectors but am having difficulty finding these. Not knowing properly what they are called Makes it hard to search Thumbs Up
Can anyone tell me what I need and where I can get them please.
Thanks.
Post #312898 15th Feb 2015 8:15pm
RiccartonRR
I think you;re looking for "ferrules" or "bootlace Ferrules".
Try and use the type where the wire goes right through rather than the blue or red ones which are crimped on like a normal spade terminal Thumbs Up
Post #312907 15th Feb 2015 8:48pm
Fish
Thanks.
I've looked at those but they look different to what I need but they may do the job.
I found a post on another forum with something similar to what I am looking for
http://forum.lro.com/viewtopic.php?f=44&t=47361
I,think you need a special crimped for these, if I can find them, so will have to check my tools as well.
Post #312926 15th Feb 2015 10:38pm
Martin
Site Admin
Where are these terminals going exactly, it's not very clear?
Post #312945 16th Feb 2015 1:13am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
http://img-europe.electrocomponents.com/images/R6139643-01.jpg
Think this is the type of connector he is after Martin
Post #312960 16th Feb 2015 8:37am
Fish
They are on the end of the wires on the caravan wiring which will then go in the back of the 13 pin plug. Push them in and tighten the screws like a plug or electrical fitting.
Thanks.
Post #312961 16th Feb 2015 8:43am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Can you not twist the wire and put them straight into the holes and then tighten the grub screw?
Failing that you should be able to find what you need here, I use this company quite a lot:
http://www.vehicle-wiring-products.eu/sect...-terminals
Post #312963 16th Feb 2015 9:08am
RiccartonRR
Fish wrote:
Thanks.
These type do need a dedicated tool to get crimped correctly. The type Ironhorse linked to are the ones I suggested not to use as the plastic end makes them too bulky for lots of jobs.
You could always get your soldering iron out and just tin the ends Thumbs Up
Post #312964 16th Feb 2015 9:20am
^ +1 for just stripping the insulation back and tinning the ends with solder. Much better job than a potentially dodgy crimp end being fitted.
Post #312985 16th Feb 2015 10:13am
Martin
Site Admin
You don't need them, as above tin the wires if you wish, but neatly stripped and twisted will do fine.
Post #312987 16th Feb 2015 10:15am
Martin
Site Admin
The terminals linked to on the LRO forum are not for this purpose, they are to go inside a connector (plug)
Post #312988 16th Feb 2015 10:16am
ironhorse
lol
every conection is potentially dodgy if not done right,even a soldered end if not done right can be bad
if a quality crimp and tool is used and a dab of grease at time of build there should never be a problem
i think the grease at build time (or lack of it) was the problem in the first place not the crimps
solder or crimp , do it right and grease it at build time
nige
Post #313004 16th Feb 2015 10:44am
Fish
Thanks for the help guys. I have looked at a million different connectors Shocked but do need uninsulated as space is tight in the connection block as there are about 10 wires going in and I already had a problem with 1 shorting out and flashing the brakes lights with the indicators as the screw on one was touching the connector on the next one.
I was considering just twisting the wires but thought I'd double check here. I thought about tinning but as the van is in storage I have no power for the soldering iron.
I'll just twist them and put them in for now, if they do go its easy to take them back out and do something else.
Post #313049 16th Feb 2015 2:55pm
Martin
Site Admin
You can get good 12V or gas powered soldering irons Smile
Post #313050 16th Feb 2015 2:56pm
I just stripped the wire on mine - then filled the whole thing with silicone to help keep moisture out and stop anything working loose over time Thumbs Up
Post #313084 16th Feb 2015 6:13pm
