![]() | Home > General > Red Diesel |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
There's a garage near me that sells red, and I was there this morning getting my MOT done. I couldn't believe how many people were pulling up and filling plastic drums |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3807 ![]() ![]() |
for red diesel 69p is blooming expensive |
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Its all that tax |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6377 ![]() ![]() ![]() |
Red diesel, the Pikie's favourite! Discovery 4 HSE
What you saying about our little sister site |
I don't know of anyone else that sells it- how much is it normally then? |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
just dont think of putting it in the FFRR or you could ebd up with a BIG bill , also that does sound very expensive onto no6 Range Rover
Listen to what Vogue said, it's a scarily true |
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
I'll "third" what Vogue said.
I suspect that they'd have a weak case if they found "evidence" of previous use. What about if like me, you've just bought the car? Who's to say that someone before me hasn't used it? |
You're probably right, but you wouldn't have much of a case if you'd owned it from new! |
unless you do have a legitimate cause to use red diesel - i.e. off the public highway!. The only thing is any trace of red and you have had it! only way out is to drain your tank and re-fill with white. I can confirm that red diesel DOES NOT stain your tank - it only leaves a trace in your filter and can quite clearly be seen through fuel sedimenters, but it won't stain metal, glass or plastic. Personal experience through using red for legit uses in tractors - off the public highway. |
