Home > Maintenance & Mods (L322) > Which auto transmission oil?
Rangeyman
Am going to attempt an oil and filter change on my 4.4 vogue petrol zf auto box.My question is when I am looking for oils on the internet it is a minefield and am sure I can find good savings on the right oil if I knew which ones are safe to use.Sure I can get the correct one from some landrover dealer that I will need a mortgage for but as I know I will have to change it at least twice what others and where can I get it?I put my reg in 'euro car parts' which listed 10 different lubricants but some reasonable prices and 'miller oils' looked good value but are they safe as am sure if I rang to check as salesmans advice is not what I am looking for.
Post #313524 18th Feb 2015 9:16pm
fisha
Esso lt 71141 iirc
Do not bother with anything else. .... Read this ... Note the comment from zf that there no alternative or equivalent,
http://www.fullfatrr.com/forum/topic28107.html?highlight=71141 V8 or else ...
Post #313527 18th Feb 2015 9:19pm
Fisha is dead right, you shouldn't use anything else..
It used to be Esso LT71141 but it is now marketed as Mobil LT71141
There are lots of oils that claim to be compatible and the oil spec is correct but they don't have the right friction modifiers needed by the torque convertor... Pete
Post #313539 18th Feb 2015 9:59pm
fisha
I got a 20l drum in the past cause doing it yourself, you only change half of the contents at a time, so I did twice separated by a few weeks. I got the 20l drum from here:
http://www.oil-store.co.uk/Mobil-ATF-LT-71...OWoWkIre-I
which is a lot cheaper than individual 1 litre bottles. V8 or else ...
Post #313600 19th Feb 2015 10:11am
rfdiii
United States 2007 Range Rover HSE 4.4 V8 Stornoway Grey
Which transmission - 5 speed or 6 speed? I believe they take different fluids, so it's an important distinction.
For the 6 speed, it's officially LifeGuard 6/Shell 1375.4. Apparently Pentosin makes an equivalent. Rumor has it, if it is available to you, that Ford's Mercon SP is also LifeGuard 6, but there is no official verification of equivalency other than Ford's documentation that the 6HP26 transmission requires Mercon SP.
Post #313876 20th Feb 2015 7:59am
Rangeyman
Ok I get that there is a risk in buying alternatives so the correct oil it will be then.Why is it they only sell it in either 1 litre tubs or 20 litres.I don't need 20 litres,where are the 5 litres or 10 litres tubs??
Post #313938 20th Feb 2015 3:41pm
espaceboy
wiki say Comma AQ3 Dexron III for 4.4V8
WRONG,
can some once change the wiki?
Post #314013 21st Feb 2015 12:08am
Rangeyman
[quote="fisha"]Esso lt 71141 iirc
http://www.fullfatrr.com/forum/topic28107....141[/quote Just to note I have just read on a Bmw forum that Valvoline max life atf is compatable although there is little to be saved.They have printed a letter from head office saying that Bmw will stand by the oil in any warranty!!!
Post #316397 5th Mar 2015 6:44pm
