![]() | Home > Maintenance & Mods (L322) > How to unblock sunroof drains? |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I have this noise also, I only tend to notice if I have the blind back so tended not to give it much thought until I saw your post. No obvious back up of water or leaks so will be interested to see replies There is a difference between knowing your sh!t and knowing you're sh!t
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7987 ![]() ![]() ![]() |
Not had to do it, but I understand it is best to use the cord from a strummer and push it down. It's strong enough to push the dirt out but bendy enough for the corners......
Elduke Member Since: 22 Apr 2013 Location: Glasgow Posts: 148 ![]() ![]() ![]() |
Some pics of the front ones here http://www.fullfatrr.com/forum/topic14068....roof+drain
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Thanks for the info, I guess I can crank it to off-road height to access the drains. I presume the top drains are easy to spot in the sunroof area also |
Just make sure you don't leave it too long especially if you are seeing misted up windows which probably means the carpets are getting wet and time to get the Pampers out |
Yes understood but it's odd as my carpets are not wet nor do I have misted up windows. I don't have any leaks. |
