Home > Maintenance & Mods (L322) > How to unblock sunroof drains?
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
I have an old thread about this but I am hoping someone can shed some light on how to unblock these sunroof drains?
When it rains, usually heavy rain, from above the front passenger seat in the sunroof area I hear a gurgling noise, oddly this appears to start and stop when the cabin blowers are on or perhaps this is coincidence.
I am no expert Surprised but it sounds to me like a drain is blocked on the left side of the sunroof area. I have no idea how to unblock it or where it is. I have heard it is under the car somewhere.
Is anyone able to tell me where all of the drains are and how many there should be. Also, any tips on how best to unblock them.
I am presuming that this gurgling noise on the one side of the sunroof is due to this??
Post #314637 24th Feb 2015 4:42pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I have this noise also, I only tend to notice if I have the blind back so tended not to give it much thought until I saw your post. No obvious back up of water or leaks so will be interested to see replies There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #314643 24th Feb 2015 5:54pm
mjdronfield
Not had to do it, but I understand it is best to use the cord from a strummer and push it down. It's strong enough to push the dirt out but bendy enough for the corners......
If you use compressed air, you can blow the tubes off the connectors and then you will be Censored
As to where they are..... I'm not sure.
Must be a diagram somewhere......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #314647 24th Feb 2015 6:34pm
Elduke
Scotland 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Some pics of the front ones here http://www.fullfatrr.com/forum/topic14068....roof+drain
I have done it myself after hearing the gurgling and used some pvc coated washing line which was rigid enough to shift the dirt from below without damaging the rubber tubes. After you clear the dirt pour some warm water into the top drains with the sunroof open to make sure it runs free from below. Thumbs Up
Post #314734 25th Feb 2015 10:48am
scwilson
Thanks for the info, I guess I can crank it to off-road height to access the drains. I presume the top drains are easy to spot in the sunroof area also Smile Will wait for some better weather and add to my list of jobs to do.
Post #314742 25th Feb 2015 11:13am
Elduke
Just make sure you don't leave it too long especially if you are seeing misted up windows which probably means the carpets are getting wet and time to get the Pampers out Big Cry
Post #314747 25th Feb 2015 11:26am
scwilson
Yes understood but it's odd as my carpets are not wet nor do I have misted up windows. I don't have any leaks.
Post #314758 25th Feb 2015 1:02pm
