![]() | Home > Maintenance & Mods (L322) > 2 wheel rollers at NCT/MOT |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
That's cleared it up. Thanks stan my mot today. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8646 ![]() ![]() ![]() |
Stan
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35713 ![]() ![]() |
if you say its for a vehicle thats running on a rolling road under its own power
A rolling road can be used for vehicles running under their own power, they also have the option to run the wheels up to speed via a built in motor, a brake tester that they use for MOT's turns under it's own power to a much slower speed, and as drive isn't engaged when brake testing it won't harm an FF
My mot man didn't go anywhere near the rollers just did a forward reverse forward test. Said he learned about rr's years ago. His first encounter was jacking up with the doors closed. Nothing about it on mot test guide. Experience is always better. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8751 ![]() ![]() ![]() |
my tester has a FF so a bit of inbuilt knowledge there....... There is nothing that can't be fixed with a hammer😜😜
Riverstick Member Since: 06 Mar 2014 Location: Cork Posts: 117 ![]() ![]() ![]() |
Most brake testers have a 4wd mode....This rotates both wheels of an axle opposite directions, therefore not turning the driveshaft of that axle, thereby not causing any strain on the centre differential/4wd system. Each wheel's brake efficiency is tested separately whilst rotating in the forward direction. 2008 Range Rover TDV8 435,000kms
