Home > Maintenance & Mods (L322) > 2 wheel rollers at NCT/MOT
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
That's cleared it up. Thanks stan my mot today. Thumbs Up
Post #316292 5th Mar 2015 10:50am
Stan
That is for rolling road testing, ie: the vehicle running on a rolling road under it's own power, that is totally different to a brake tester, which is not called a rolling road.....
They are two totally different machines.... Pete
-Click here for Thread-
Post #316330 5th Mar 2015 1:29pm
if you say its for a vehicle thats running on a rolling road under its own power
what does this mean then?
Post #316349 5th Mar 2015 2:38pm
A rolling road can be used for vehicles running under their own power, they also have the option to run the wheels up to speed via a built in motor, a brake tester that they use for MOT's turns under it's own power to a much slower speed, and as drive isn't engaged when brake testing it won't harm an FF
A lot of MOT places use the decelerometer to test 4x4's just to placate owners.... Pete
Post #316354 5th Mar 2015 2:46pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
My mot is due in may. What should I do ? Tell them not to test the brakes ? Wouldn't that be a fail ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #316535 6th Mar 2015 12:20pm
gregdav
My mot man didn't go anywhere near the rollers just did a forward reverse forward test. Said he learned about rr's years ago. His first encounter was jacking up with the doors closed. Nothing about it on mot test guide. Experience is always better. Thumbs Up
Post #316536 6th Mar 2015 12:27pm
my tester has a FF so a bit of inbuilt knowledge there....... There is nothing that can't be fixed with a hammer😜😜
Post #316596 6th Mar 2015 6:20pm
Riverstick
Ireland 2015 Range Rover Autobiography SDV8 Santorini Black
Most brake testers have a 4wd mode....This rotates both wheels of an axle opposite directions, therefore not turning the driveshaft of that axle, thereby not causing any strain on the centre differential/4wd system. Each wheel's brake efficiency is tested separately whilst rotating in the forward direction. 2008 Range Rover TDV8 435,000kms
2015 Range Rover L405 SDV8 Autobiography
2008 Ford Focus1.6 tdci Titanium DPF deleted
Post #317775 13th Mar 2015 1:06am
