Home > In Car Electronics (L322) > Info please
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Info please
My sound system seemed to stick last night! Couldn't turn volume up or down or shift from cd to radio?? Did turn the screen off on the way home? Would that have any significance??
Hopefully when I go out this morning, normal service will resume??
Thanks in advance
David 2014 vogue se
Post #316500 6th Mar 2015 9:35am
chefkenmore
Normal service has resumed!!
What a great sound system!
Wonder what caused that??
David 2014 vogue se
Post #316509 6th Mar 2015 10:22am
Discotigger
I had exactly the same thing happen to my satnav unit a couple of weeks ago. Set off early one morning to go from Home downto Chorley, the cd wouldn't change to radio (although I could change cd's on the touchscreen, none of the steering wheel controls worked and couldn't adjust the volume at all. Stopped for a coffee at Killington Lake services, when I restarted the FF after about 10 minutes...normal service resumed and everything worked perfectly Confused .
I just put it down to a glitch (possibly software related, like when a computer 'hangs') that reset itself once the engine and electrickery had been shut off.
All good now, so not unduly worried. Thumbs Up
Post #316516 6th Mar 2015 10:42am
Mine did exactly the same the other night coming home! Tried turning the car off & on again but needed to wait 10mins for the system to go to sleep and all started up fine again! Bizarre Rolling Eyes
Post #316519 6th Mar 2015 10:45am
Discotigger
Hmmmm, that's a bit weird. Shocked
I wonder if it could be anything related (or similar) to the problem encountered when the 4G service was started up a year or so back, when the satnav systems were shutting down and restarting after a second or so because of the signal interference. Not had that problem reoccur, but for the same 'glitch' to happen to three FFs at once seems a bit too much of a coincidence.
Thoughts anyone? Whistle
Post #316520 6th Mar 2015 10:57am
its more likely that its not getting the correct voltage on startup and therefore not switching on properly..a bit like the screen which sometimes will switch on dull then when you restart with a healthier battery, its ok.. ... - .- -.
Post #316522 6th Mar 2015 11:00am
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
I've had the same thing as Craig, where I needed to let it all shut down totally.
I also had a thing where the auto volume level kept increasing on the motorway but that settled down after turning the source off with the standby button Rolling Eyes
Gremlins Laughing Shocked
Post #316523 6th Mar 2015 11:01am
Discotigger
That's a good point you make Stan, it could be voltage related, but I've never had the dull screen glitch though. On the morning in question that this glitch happened to me, it was quite cold but didn't have any problem starting the FF and didn't get any HDC Inactive warning. I didn't notice any problem with the system till after I had been driving for about 15 minutes (I had got on the M6 and went to turn up the volume),.
It's just a bit strange how this particular glitch has only ever happened once (so far!), never had any problem exactly like that before or since. I have had the odd occasion where, on stopping and restarting the FF after refuelling, etc., the cd player hasn't come on and I've had to press the 'On/Off' button on the satnav to restart the cd player, and experienced the 4G Signal 'cut-out' problem when that was ongoing a year or so back (again, that seems to have resolved itself, mysteriously, as never got any definitive answer or solution).
Probably is just a Gremlin...
Just need to remember not to feed the FF after midnight or get her wet! Rolling with laughter
Post #316529 6th Mar 2015 11:52am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Yep me too. Had it a couple of times now and after restart ok.
Glitches got to be Very Happy
Post #316540 6th Mar 2015 12:32pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I had it once after I accidentally set the alarm off, no screen, no radio control and no camera although radio worked. Driven about 10 mins, parked up and when I came back all working fine. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #316543 6th Mar 2015 12:38pm
Weegie
Just another FFRR idiosyncrasy. Happens from time to time. Switch off and then back on usually cures it. Adds to the personal relationship with the car. Very Happy John
GAP iiD BT-Sold
Post #316564 6th Mar 2015 3:26pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I'm glad it's not just me! Mine froze the other night, turned it off and on again and got a black screen no sound. Like Craig, worked after the 10 minute nap! Laughing My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #316566 6th Mar 2015 3:33pm
