![]() | Home > In Car Electronics (L322) > Info please |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 761 ![]() ![]() ![]() |
Normal service has resumed!!
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
I had exactly the same thing happen to my satnav unit a couple of weeks ago. Set off early one morning to go from Home downto Chorley, the cd wouldn't change to radio (although I could change cd's on the touchscreen, none of the steering wheel controls worked and couldn't adjust the volume at all. Stopped for a coffee at Killington Lake services, when I restarted the FF after about 10 minutes...normal service resumed and everything worked perfectly |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Mine did exactly the same the other night coming home! Tried turning the car off & on again but needed to wait 10mins for the system to go to sleep and all started up fine again! Bizarre |
Hmmmm, that's a bit weird. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
its more likely that its not getting the correct voltage on startup and therefore not switching on properly..a bit like the screen which sometimes will switch on dull then when you restart with a healthier battery, its ok.. ... - .- -.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
I've had the same thing as Craig, where I needed to let it all shut down totally.
That's a good point you make Stan, it could be voltage related, but I've never had the dull screen glitch though. On the morning in question that this glitch happened to me, it was quite cold but didn't have any problem starting the FF and didn't get any HDC Inactive warning. I didn't notice any problem with the system till after I had been driving for about 15 minutes (I had got on the M6 and went to turn up the volume),.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Yep me too. Had it a couple of times now and after restart ok.
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 ![]() ![]() ![]() |
I had it once after I accidentally set the alarm off, no screen, no radio control and no camera although radio worked. Driven about 10 mins, parked up and when I came back all working fine. There is a difference between knowing your sh!t and knowing you're sh!t
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Just another FFRR idiosyncrasy. Happens from time to time. Switch off and then back on usually cures it. Adds to the personal relationship with the car. |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
I'm glad it's not just me! Mine froze the other night, turned it off and on again and got a black screen no sound. Like Craig, worked after the 10 minute nap! |
