Home > Maintenance & Mods (L322) > Slight knock developing on front end?
Garyfax
England 2009 Range Rover Vogue SE TDV8 Santorini Black
Hi Folks.
I have started to develop a slight
knock on my front suspension when
going over bumps.
Any ideas what to look for before I
start replacing bushes etc?
Cheers
Post #319174 23rd Mar 2015 10:39am
Not enough air in the front tyres??? Whistle Whistle Whistle
Post #319177 23rd Mar 2015 10:44am
Sorry Gary i could not resist Bow down
Basics really when knocking, get it on a ramp and check for movement with a lever bar sir Thumbs Up
Post #319178 23rd Mar 2015 10:46am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Recently changed all mine, track rod ball joints where shot, and the 4 lower ball joints and arms, all parts sorced from Dan at Duckworth LR Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #319179 23rd Mar 2015 10:47am
razzer
England 2003 Range Rover HSE Td6 Zambezi Silver
mine started knocking from the front nearside, turned out to be a very slightly worn track rod end, replaced it and the knock went away.
Post #319180 23rd Mar 2015 10:52am
Garyfax
Thanks folks..
Craig, I suppose I walked into that one didn't i? Very Happy
Post #319181 23rd Mar 2015 10:59am
A little sir Bow down Bow down Bow down Whistle Thumbs Up
Post #319183 23rd Mar 2015 11:02am
I had a lower track control arm replaced for a similar noise but in reality it could be any part of the front suspension. Got - 2017 SDV8 Autobiography in Loire Blue
Post #319186 23rd Mar 2015 11:20am
Discotigger
Check the Anti-Roll Bar Drop Links, they're a common reason for the knocking.
Fairly easy to check, cheap to replace and easy to replace too. Thumbs Up
Post #319197 23rd Mar 2015 1:22pm
Garyfax
Thanks. I will have a look at droplinks.
MOT in the morning so see what they
pick up.
Post #319298 23rd Mar 2015 9:23pm
Garyfax
MOT man passed the car with an advice on the o/s Bottom ball joint.
Bought the part, fitted it in an hour and its sorted. £50 for the part and fitted with a mate.
Thanks Folks
Post #319450 24th Mar 2015 6:25pm
Happy days Thumbs Up
Well worth having an alignment check done now though sir as once you notice the front tyres wearing it will be too late! And a lot more expensive than a geometry check Thumbs Up
Post #319460 24th Mar 2015 6:50pm
Garyfax
Thanks for your advice once again
Craig, will do.👍
Post #319514 25th Mar 2015 6:25am
Post #319520 25th Mar 2015 8:03am
