![]() | Home > Maintenance & Mods (L322) > Slight knock developing on front end? |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 ![]() ![]() ![]() |
Hi Folks.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Not enough air in the front tyres??? |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Recently changed all mine, track rod ball joints where shot, and the 4 lower ball joints and arms, all parts sorced from Dan at Duckworth LR |
razzer Member Since: 20 Feb 2015 Location: blackpool Posts: 54 ![]() ![]() ![]() |
mine started knocking from the front nearside, turned out to be a very slightly worn track rod end, replaced it and the knock went away. |
Thanks folks..
A little sir |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
I had a lower track control arm replaced for a similar noise but in reality it could be any part of the front suspension. Got - 2017 SDV8 Autobiography in Loire Blue
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 ![]() ![]() ![]() |
Check the Anti-Roll Bar Drop Links, they're a common reason for the knocking.
Thanks. I will have a look at droplinks.
MOT man passed the car with an advice on the o/s Bottom ball joint.
Happy days |
Thanks for your advice once again
