Home > Technical (L322) > Towing indicators
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Towing indicators
Just back from holiday with our caravan! Read the manual and I'm sure it tells me that, when I connect the black 7 pin plug, the trailer symbol should flash in unison with the indicator arrow??
Trailer symbol lights up on my dash continually but doesn't flash when the indicators are switched on! Is this right???
David 2014 vogue se
Post #320658 31st Mar 2015 2:47pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
It's different for different model years, but essentially nothing beats your pre-check walkaround does it? Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #320660 31st Mar 2015 2:54pm
n1cktdv8
Mine is same as yours...and that is correct so it's all working Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #320669 31st Mar 2015 3:29pm
Yep - I have the same model & year - mine stays constantly illuminated as long as the trailer is attached Thumbs Up
Post #320670 31st Mar 2015 3:32pm
tenera
United Kingdom 2006 Range Rover Vogue SE Td6 Zambezi Silver
I've just fitted a new witter towbar, and genuine JLR plug and play 13 pin electrics, to my recently bought MY2006 RR vogue se. When I connected up, the RH & LH indicators, didn't make the green trailer light on the dash flash in time with the normal indicators, and it stays lit up all the time whist the 13 pin is connected up. Disconnect the plug, green lights goes out.
After reading the handbook, it stated that it should flash in time with the normal indicators, so as a check to ensure that there was some sort of non working warning, I disconnected a bulb on the back of the caravan, then, it flash's really quickly, letting you no that all least 1 bulb has stopped working.
So it sort of works, not exactly as per the book, but still complies with giving a warning too you. Thumbs Up
Post #321281 5th Apr 2015 9:17am
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Just been caravanning with the SC this week, trailer tow lamp remains on constantly, info entre on instruments tells me if there is a bulb out, if indicator is out flash rate is quick (had this with my car trailer)
My car has a 13 pin plug, first time I have had proper caravan electrics too!
58 plate 4.2 SC Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #321283 5th Apr 2015 9:29am
It stays on permanently to tell you the trailer is plugged in! When it senses a fault it will either ping up on the display or flash quickly or both Thumbs Up
Post #321285 5th Apr 2015 10:13am
I think the handbook is out of sync, and is still referring to the pre facelift models where it flashed....... Just a page they forgot to change it seems. There is nothing that can't be fixed with a hammer😜😜
Post #321300 5th Apr 2015 1:40pm
