![]() | Home > Technical (L322) > Towing indicators |
It's different for different model years, but essentially nothing beats your pre-check walkaround does it? Land Rover Addict
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Mine is same as yours...and that is correct so it's all working |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8102 ![]() ![]() ![]() |
Yep - I have the same model & year - mine stays constantly illuminated as long as the trailer is attached |
tenera Member Since: 08 Mar 2015 Location: York Posts: 6 ![]() ![]() ![]() |
I've just fitted a new witter towbar, and genuine JLR plug and play 13 pin electrics, to my recently bought MY2006 RR vogue se. When I connected up, the RH & LH indicators, didn't make the green trailer light on the dash flash in time with the normal indicators, and it stays lit up all the time whist the 13 pin is connected up. Disconnect the plug, green lights goes out.
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 ![]() ![]() ![]() |
Just been caravanning with the SC this week, trailer tow lamp remains on constantly, info entre on instruments tells me if there is a bulb out, if indicator is out flash rate is quick (had this with my car trailer)
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16399 ![]() ![]() ![]() |
It stays on permanently to tell you the trailer is plugged in! When it senses a fault it will either ping up on the display or flash quickly or both |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8769 ![]() ![]() ![]() |
I think the handbook is out of sync, and is still referring to the pre facelift models where it flashed....... Just a page they forgot to change it seems. There is nothing that can't be fixed with a hammer😜😜
