![]() | Home > In Car Electronics (L322) > amplifier wet no sound |
jdig Member Since: 12 Mar 2015 Location: england Posts: 12 ![]() ![]() ![]() |
Sorry forgot to mention
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
You might want to fill in your car details sir, then members with similar spec'd vehicles can help with your question |
Cheers just done that |
this any good?
I have seen that post thanks
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
You need to fix the leak and fit the water shedder from Land Rover before you put a replacement amp in.....
Good call above |
I have been trying to find the source even blocked up the back section & used smoke pellets then shut the tailGate a small amount of smoke escaped out the tailGate where they both butt together also been in the back & had someone else hose water all over I suspect it's when I was bringing it to car wash places & they use a pressure washer I've not been brave enough to try that yet
Water will find its way in much easier than smoke finding its way out sir! |
