![]() | Home > Maintenance & Mods (L322) > Suspension Fault | 2008 RR VOGUE SC |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
You say you don't use it.... it is working every time you drive the car, always making adjustments to keep you level, so it does work hard even if you don't play with the buttons..
| luv2xlr8 Member Since: 29 Mar 2015 Location: Dubai Posts: 57
"Suspension Fault" appears…no particular reason but mainly when driving or at the traffic lights.
| Big Tings Member Since: 03 Apr 2015 Location: Vogue Posts: 22
@Haylands, spot on mate just had to change my front passenger side due to a leak. If the compressor is working overtime to keep the leak inflated it will overheat and stop. Was driving mine on bump stops to get home after the bag let go on a trip. Note that the bags can reseal (leak hole becomes covered) until it is moved again by going over a bump etc. When we changed the passenger bag we took a look and the rubber had perished to the point that when we put it under manual load it was cracked all over. |
Grabbing the car today, hope all goes smooth after the sensor replacement.
Good news, car is driving just fine. If I hadn't rushed, would of cost me considerably less, its a first with the dealer so harm done and car drives just fine now. |
Back to to where it started, car on the ground, same messages |
Another sensor or a leak or possibility that someone has programmed the system into tight tolerance mode, this can make it work very hard and overheat the compressor...
Brilliant how you jump out the rocks with the support and feed back, its rather exciting, thanks Haylands.
Personally I wouldn't bother changing just the bag, FF's are heavy and the shock will be worn...
Thank you sir. I'll have a look!
Fronts take about an hour, rears about 30mins... very quick to do...
Brilliant, thank you |
What needs tuning.....??? The engines tune themselves, there are no adjustments you can make, it either runs fine or something has failed....
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6432
luv2xlr8 means calibration (tuning), I think.
