![]() | Home > In Car Electronics (L322) > Replacement reversing camera - help |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872 ![]() ![]() |
red and black are power, yellow is normally the inner wire for the video feed..cant make out if there's an outer braiding of some kind.. ... - .- -.
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Hi Stan
thats a plan...
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
I can't understand why theres a 5th wire.
No instructions I'm afraid, going to try to connect the White wire as the outer video cable. Let you know how it goes later |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 413 ![]() ![]() ![]() |
Seems like you have one of these:
Hi VVMP
Ethanicus Member Since: 23 Feb 2015 Location: Surrey Posts: 34 ![]() ![]() ![]() |
My understanding of these when I fitted one to a friend’s pioneer av screen on a 350z is as follows:
Chopped off the cables, stripped them, and connected all together. You have, under the tailgate upper trim, 2 connectors. One for the video and one for the power. The power is a white plug with the red and black wires and the video is a very small RCA type connector. You can chop them before (leave enough cable) the connectors and then and hardwire them together. That's what I did except for the video part. By my mistake, I chopped the video after the connector and ended up having to connect it without using the original connector. So for the power I'm using the original connector and for the video I had to hardwire them together. |
