Home > In Car Electronics (L322) > Replacement reversing camera - help
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
I'm in the process of replacing my rear view camera on my 2006 tdv8 but I can't get a picture on the new camera. The camera is the same as another forum member purchased which was successfully installed. The problem may be because I've connected the wires incorrectly. Can anyone advise as to the correct connections please
I've tried to find the original post without success.
Post #322022 10th Apr 2015 10:48am
red and black are power, yellow is normally the inner wire for the video feed..cant make out if there's an outer braiding of some kind.. ... - .- -.
Post #322027 10th Apr 2015 11:24am
Buz1500
Hi Stan
There's no braiding on the yellow, perhaps I need connect one of the unused wires to the braiding on factory cable?
Buz
Post #322033 10th Apr 2015 12:24pm
thats a plan...
any instructions with the camera? ... - .- -.
Post #322069 10th Apr 2015 2:57pm
I can't understand why theres a 5th wire.
I agree that red is +12v, black is -ve, yellow and white are most likely inner & outer camera cable
Is there a microphone, or LED's in the unit ?
Post #322072 10th Apr 2015 3:04pm
Buz1500
No instructions I'm afraid, going to try to connect the White wire as the outer video cable. Let you know how it goes later
Post #322075 10th Apr 2015 3:23pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Seems like you have one of these:
http://www.ebay.co.uk/itm/231390415722?_tr...EBIDX%3AIT
I've fitted one of those to my car, and i'm pretty happy with the result
Post #322079 10th Apr 2015 3:41pm
Buz1500
Hi VVMP
Could I ask how you connected it to the car wiring
Post #322093 10th Apr 2015 4:56pm
Ethanicus
England 2010 Range Rover Vogue SE TDV8 Stornoway Grey
My understanding of these when I fitted one to a friend’s pioneer av screen on a 350z is as follows:
As pre stans comments:
RED: IGN Hot +
BLACK: NEG –
YELLOW: Video Out / Video IN Feed to Head Unit (If connecting to a RCA jack, you may need to link the shield to Camera Black (earth
GREEN: Keep Disconnected\capped unless you want a solid white line on the screen (parking aid/guide).
WHITE: Depending on the camera it changes then origination of the lens (front or rear facing). If using for rear camera you may need to loop this to earth (black cable). or Positive (red)
If you can test on a 12v bench power supply, it may avoid any damage in testing. 2010 - Range Rover VSE 3.6 TDV8
2014 - Defender 90 XS
2014 - Suzuki Swift Sport
2017 - GBS Zero
2006 - BMW Z4M Coupe (gone)
2004 - Discovery Landmark TD5 Auto (gone)
2008 - Defender 90 SX (gone)
2011 - Touareg Altitude (gone)
Post #322099 10th Apr 2015 6:07pm
VMPP
Buz1500 wrote:
Hi VVMP
Chopped off the cables, stripped them, and connected all together.
You have, under the tailgate upper trim, 2 connectors. One for the video and one for the power. The power is a white plug with the red and black wires and the video is a very small RCA type connector.
You can chop them before (leave enough cable) the connectors and then and hardwire them together.
That's what I did except for the video part. By my mistake, I chopped the video after the connector and ended up having to connect it without using the original connector. So for the power I'm using the original connector and for the video I had to hardwire them together.
Post #322409 13th Apr 2015 11:52am
