Home > In Car Electronics (L322) > Sat nav works on screen but no data on other buttons
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Got a friend with a TDV8. When you push any of the six buttons around the central screen it shows all the screen backgrounds but none of the data. The exception to this is the sat nav which seems to work correctly. When you press the radio what it comes up with is the word preset instead of all the radio stations and the volume control on the screen won't work. When you switch to phone it says no phone fitted which isn't the case. It all worked until recently. The mpg shows on the single line screen on the dash but when you go to the computer screen all the background is there properly but the boxes with the numbers are all blank. When you go to the 4x4 screen it shows everything but the wheels don't turn and it doesn't tell you the ride height in the top right corner.
Also when you put it into reverse the reversing camera doesn't come on.
Have had a few of the fibre-optic connectors out and they all appear to be clean. The radio does work but only on one station. The volume can only be controlled from the steering wheel. Have checked in the near side rear compartment and all appears to be dry. It works but only on one station.
The battery is new.
Anyone encountered anything like this before? Is there a fuse which controls the data as opposed to the screen backgrounds?
Thanks. Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #293632 16th Nov 2014 11:26pm
malkyo
United Kingdom 2007 Range Rover SE TDV8 Zambezi Silver
Hi Dijit
I have the exact same problem with my 2007 TDV8, I have tried resetting the system by disconnecting the battery over night but nothing, it was working ok except for the phone never worked, if you disconect the fibre optic you loose the radio.
Have you found a solution yet?
Post #301646 29th Dec 2014 5:01pm
malkyo
Hi David,
Thanks for getting back to me, I still have the same problem, I have isolated each device on the fibre optic MOST network, even stripping down the dash to get to the CD player, so far I've got as far as I can go, I have spoken to a local garage and they are going to have a look in the next 2 weeks.
Have you had any joy with yours?
Regards
Mal
P.s. Not able to pm you as I've not sent enough posts yet, probably will after this post
Post #322321 12th Apr 2015 2:51pm
How have you isolated each device?
Post #322326 12th Apr 2015 3:40pm
have you done a 'proper' battery disconnection.. ... - .- -.
Post #322335 12th Apr 2015 3:55pm
malkyo
Hi Cam Tech Craig & Stan,
I have isolated each component by disconnecting each device and using a fiber optic link in place to complete the optic link.
I have done a reset by both disconnecting overnight and by holding the terminals on the battery together (obviously off the battery).
The car worked fine for a month and then I couldn't select AUX, CD, TV, also nothing on the terrain response shows, Fuel computer (although it shows on the dash display), volume control, reverse camera, venture cam, telephone, voice control, plus probably more doesn't work.
In the on-board diagnostics it doesn't show reverse gear, however the reverse lights come on, volume is controlled via steering wheel controls but the re tune buttons does not respond. There is no sound from the Sat Nav but otherwise works well. the other thing that works is the radio but none of the presets show the station name and you have to go into the tuning setting to scan to a station. In the diagnostics all soft and hard buttons show working.
Love the car, to me it is my ultimate vehicle, I would really love to have it all working.
FYI 2007 Vogue SE TDV8
Any help or pointers would be much appreciated
Mal
Post #322340 12th Apr 2015 4:21pm
Dijit
Mal,
Have PM'd you.
Dijit Rehab is for quitters!!!
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #322343 12th Apr 2015 4:41pm
Sounds very much like the BT module to me... They do like to throw up some really strange faults!
Post #322353 12th Apr 2015 6:11pm
malkyo
I had bypassed it as it wasn't working and since bought a new one, I'm pretty sure it is not that bad boy, thanks
Post #322360 12th Apr 2015 6:36pm
malkyo
Hi All,
As a follow up to complete the story, I purchased and had fitted a new screen which has the IHU (integrated Head Unit) and hey presto it now all works perfect.
Hope this helps others that may have same problem.
FYI got a new one off ebay for £270
Post #354236 26th Oct 2015 4:21pm
Dijit
Malkyo, were you present when the screen was swapped? Do you still have the old screen? I'm asking as I'd like to know how easy it is to remove the screen and secondly if it could be something as simple as a dry solder joint?
Thanks,
Jaguar 420 (1969) *
Nissan 300Z
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Departed
LR 1992 110 2.5TD
Post #354239 26th Oct 2015 4:35pm
malkyo
Hi Dijit,
the top of the dash has to come apart to gain access to the screen, it will take several hours to do, I still have the old screen. I did take the dash apart before to test the cd player and it took me several hours but that was the first go,
I'm sure I sent you an email a week or so ago to let you know that it got fixed, not sure if you got it or it's sitting in you spam box.
Hope this helps
Malkyo
Post #354242 26th Oct 2015 4:55pm
ppcsl
Scotland 2005 Range Rover Autobiography Td6 Java Black
Hi, This is almost identical to what is happening to me except the radio is intermittent (still only on one station though). I was starting to think it was the radio tuning unit VUX500103. The system mainly didn't work through the summer when it was much warmer, well sun through the screen made the dash really hot. So it does make sense that it could be the head unit.
I almost bought the tuning unit from the States just now but thought I would check the forum to see if there was any new info, luckily I did. I will now go and try and find a reasonable head unit on EB.
Fingers crossed it will fix it. It has only not worked properly for about two years so no big deal Evil or Very Mad Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #356558 12th Nov 2015 10:23pm
Zirconblue
BBA Reman do repairs on multifunction screens. Might be worth a go.
Post #356581 12th Nov 2015 11:59pm
ppcsl
Thanks for the info on BBA I will drop them an email and see if i can get some prices from them. Traded in my Audi TT 225 for my Range Rover TD6 Autobiography in Java Black. Range Rover now sold.
Post #356758 13th Nov 2015 8:57pm
