![]() | Home > My Range Rover > Project Fatty off roader....PICTURES NOW BACK |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8772 ![]() ![]() ![]() |
Kaj, If it still has the aluminium box with fins attached then that is a soft start relay, this is the diagram for it
Brown/Green is a permanent 12v supply rated at 80amps White/Green is an ignition 12v supply rated at 15amps Black is an earth, should be the same size wire as Brown/Green White/Blue is the control wire, I used a generic fan controller with a take off from the top hose I fixed the fan to the rad with cable ties, drilled two holes through the top edge of the radiator in line with the two plastic hooks, and used cable ties to hold them in place. I cut off the top two side hooks as the bottom side mounts are in the same place as two plastic retainers for the original fan shroud I drilled two holes through the fan fixings and used cable ties through the fan shroud and around the plastic lugs on the rad. I used a meter to find an ignition switched live in the ECU box...
PM sent sako243, yep, they are pretty unstoppable offroad, I've embarrassed a few Defenders....... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- Last edited by Haylands on 4th Jun 2022 12:24pm. Edited 1 time in total |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
I've yet to get to grips with it on slippery wet grass / mud. Too much weight and not enough tread but then I do have ATs on rather than than those fitted to the Defender...
Having had a look under it in the pit last night I seem to have demolished the skid plate underneath the sump so maybe time to invest in a bash plate. Might ask the local trailer company if they can build one - knowing their workmanship it will be a damn sight cheaper, easier to source and better quality than most available. Regards Ed |
Went for it's MOT today, had it nearly a year now and done 16,000 miles in it, taken it swimming and mountain climbing, driven it like an old granny and sometimes like I stole it....
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
That's impressive Pete.
Mark,
Just updating this thread and keeping everything in one place...
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
That fix looks first class |
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
Does the 32" wheel fit in the spare wheel well? |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902 ![]() ![]() ![]() |
Top job on the seat Pete, funny how they all split there! |
Chex, I don't know mine is full of LPG tank... I would imagine it probably wouldn't, the normal one looks tight enough...
Thanks for getting back to me |
Haylands are you still running without a thermostat? Any problems? |
Ran it for a few months without one, didn't seem to mind, then it started getting colder so I fitted an 80deg one.... Pete
