Home > In Car Electronics (L322) > Mysterious Alarm trigger
Here's a weird one.
My alarm keeps going off - this happens.
But, I've noticed it's almost the exact same time each day 12:40.
When I go to unlock, deactivate and put the ignition on, the dashboard tells me the bonnet is open, which it is not.
What could be causing this? Discovery 4 HSE
1993 90 Tdi
Post #324932 29th Apr 2015 12:52pm
bonnet switch, test it by connecting the two wires together.. ... - .- -.
Post #324941 29th Apr 2015 1:33pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
You can adjust the bonnet fit. Spray the alarm widget with wd40 too.
Post #324951 29th Apr 2015 2:36pm
I did the latter. No change.
With the bonnet open and a hammer resting on the switch the dash message goes away, so the switch does work at times, yet for some reason trips in the middle of the day only. Discovery 4 HSE
1993 90 Tdi
Post #324967 29th Apr 2015 3:34pm
supershuttle
Your getting warmer - see what I did there Very Happy Geoff
Post #324972 29th Apr 2015 3:42pm
Why would the warmth of the middle of the day trip it??
It's also the only thing I can think of that occurs at the same time of the day. Sunlight! Discovery 4 HSE
1993 90 Tdi
Post #324974 29th Apr 2015 3:43pm
supershuttle
12:40 exactly suggests something else maybe, but I found that "at the going down of the sun and in the morning" my alarm went off.
Lawrence Binyon gets credit for the bit of my post in quotes. Thumbs Up Geoff
Post #324985 29th Apr 2015 4:01pm
well, 12:40 thereabouts, it was only today it clicked that it was pretty much the same time. I havent checked every day and can't, as the car is mostly in Heathrow car parks. Discovery 4 HSE
1993 90 Tdi
Post #324993 29th Apr 2015 5:28pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
You have a black car, the sun is shining, the metal / plastic deforms, the alarm goes off
try parking in the shade
Post #324994 29th Apr 2015 5:33pm
I don't have any shade any more Big Cry Discovery 4 HSE
1993 90 Tdi
Post #324997 29th Apr 2015 5:44pm
supershuttle
I think the fix I described earlier will sort it - it did mine Very Happy Geoff
Post #324999 29th Apr 2015 6:08pm
Zirconblue
Buy a taylored car cover (LR do them i think), it'll be lighter, reflect the heat and stop the birds crapping on your car. Laughing
(this isn't really a serious suggestion)
Post #325006 29th Apr 2015 7:20pm
Roystonh
Just had that happen to me - on holiday in Spain! Bonnet showing open when it wasn't and alarm kept going off. Had a new bonnet sensor fitted today - hopefully that's sorted it. 2005 L322 Vogue Gold gone
2006 L322 Vogue Black gone
2011 L322 Vogue Silver gone
2011 L322 Autobiography Black gone
2015 L405 Autobiography LWB Black gone
2019 L405 P400e Range Rover Autobiography LWB Eiger grey / black roof gone
2001 P38a 30th Anniversary Wimbledon Green gone
2019 L405 P525 Autobiography LWB British Racing Green
Post #325037 29th Apr 2015 10:10pm
Watty
Scotland 2017 Range Rover Autobiography SDV8 Santorini Black
Re: Mysterious Alarm trigger
Unnecessary quote removed
This happened to me the bonnet is not keeping pressure on the switch causing the alarm to activate. I put some sticky tape on top of the switch increasing the switch height solved the problem a very common fault 07 Vogue SE Java Black 3.6 TDV8
Black Leather heated/ cooled seats
Piano black trim deployable side steps
L405 Autiobiography 2017
Santorini Black with black pack
13 L405 4.4 Autobiography
Post #325046 30th Apr 2015 12:31am
modbarra
Scotland 2019 Range Rover Autobiography 5.0 V8 Loire Blue
I used a self adhesive wheel balance weight stuck under the bonnet until got replacement switch.... That worked.
Post #325049 30th Apr 2015 5:23am
