![]() | Home > In Car Electronics (L322) > Mysterious Alarm trigger |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383 ![]() ![]() |
Here's a weird one.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35868 ![]() ![]() |
bonnet switch, test it by connecting the two wires together.. ... - .- -.
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
You can adjust the bonnet fit. Spray the alarm widget with wd40 too. |
I did the latter. No change.
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962 ![]() ![]() ![]() |
Your getting warmer - see what I did there |
Why would the warmth of the middle of the day trip it??
12:40 exactly suggests something else maybe, but I found that "at the going down of the sun and in the morning" my alarm went off.
well, 12:40 thereabouts, it was only today it clicked that it was pretty much the same time. I havent checked every day and can't, as the car is mostly in Heathrow car parks. Discovery 4 HSE
I don't have any shade any more |
I think the fix I described earlier will sort it - it did mine |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Buy a taylored car cover (LR do them i think), it'll be lighter, reflect the heat and stop the birds crapping on your car. ![]() (this isn't really a serious suggestion) |
Roystonh Member Since: 21 Nov 2011 Location: Kent Posts: 395 ![]() ![]() |
Just had that happen to me - on holiday in Spain! Bonnet showing open when it wasn't and alarm kept going off. Had a new bonnet sensor fitted today - hopefully that's sorted it. 2005 L322 Vogue Gold gone
Watty Member Since: 03 Oct 2013 Location: Kirkintilloch Posts: 56 ![]() ![]() ![]() |
Unnecessary quote removed
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 ![]() ![]() ![]() |
I used a self adhesive wheel balance weight stuck under the bonnet until got replacement switch.... That worked. |
