Home > Technical (L322) > Front diff removal plug
viper
Bought me a nice 1/2 drive 14mm hex socket to remove the drain plug and the bloody chassis is in the way , what tool do you guys use? the hex is just in at an angle and the plug is turning but im going to hit the chassis before its out and chew up the plug
Post #325294 1st May 2015 11:21am
craig-meister recommended this kit in on of his posts,
http://www.ebay.co.uk/itm/Oil-SUMP-Plug-Ke...rmvSB=true
Post #325303 1st May 2015 11:50am
Weegie
I cut the end off a 14mm allen key and used a 14mm 1/2in drive socket rather than buying the ready made hex drive (being a Scot Very Happy). As it only required a short length of it, the allen key was still usable as such afterwards.
If you did the same and cut the length so that it fitted the plug with just enough protruding to get a ratchet spanner (or an open ender) on it solidly you should have sufficient clearance.
You won't get a torque wrench on it but that shouldn't present any great problem in tightening it up sufficiently.
HTH John
GAP iiD BT-Sold
Post #325322 1st May 2015 12:35pm
I just cut down a 14mm allen key so that it fitted in the gap.
Post #325324 1st May 2015 12:53pm
14mm Allen sump key and a spanner is all that's required. Short than 1/2" drive tools and able to fit into tight spaces Thumbs Up
Post #325333 1st May 2015 1:13pm
johnboyairey
without using the ratchet to fully remove, can you not use a spanner on the hex key (on the socket) to wind it out... ring spanner over first, locate, and presto
Post #325342 1st May 2015 1:42pm
viper
great tips, thanks
Post #325374 1st May 2015 3:14pm
viper
ive got one of those in my Kawasaki tool kit, for taking off the front wheel, I will use it
cheers Thumbs Up
Post #325376 1st May 2015 3:15pm
