![]() | Home > Technical (L322) > Front diff removal plug |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
Bought me a nice 1/2 drive 14mm hex socket to remove the drain plug and the bloody chassis is in the way , what tool do you guys use? the hex is just in at an angle and the plug is turning but im going to hit the chassis before its out and chew up the plug
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
craig-meister recommended this kit in on of his posts,
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
I cut the end off a 14mm allen key and used a 14mm 1/2in drive socket rather than buying the ready made hex drive (being a Scot |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3981 ![]() ![]() ![]() |
I just cut down a 14mm allen key so that it fitted in the gap. |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
without using the ratchet to fully remove, can you not use a spanner on the hex key (on the socket) to wind it out... ring spanner over first, locate, and presto |
great tips, thanks |
ive got one of those in my Kawasaki tool kit, for taking off the front wheel, I will use it cheers ![]() |
