![]() | Home > Maintenance & Mods (L322) > Air conditioner compresor/fan making intermittent squeeling |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8794 ![]() ![]() ![]() |
Sounds like a worn bearing on the compressor clutch, they will soldier on for ages though, just a bit noisy.... Pete
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
Drive belt slipping? |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
No idea about drive belt. Iat starts doing it/stops doing it only when the AC is on/off.
Will eventually fail but that can take years, if you can find someone to strip and rebuild the compressor then that's the cheapest way, if not it's get a new one time....
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
have yet to fix this on mine. i think mine is compressor though, as it sounds ok until i switch the ac on, then it squeals. have brought second hand compressor off a bmw x5 when i get round to it i'll get a local aircon man to come and have a look and try vacuum test first if thats ok it may just need regassing and some oil putting in.
Greg, keep meaning to look at mine as the bearing grumbles... can you take the front pulley off with it still on the car, does it just unbolt??
i havn't tried but have been underneath access is very limited, as i was stuck for time (as usual ) i tried the tensioner first to see if i could release the belt being by the rad i did'nt want to push it and gave up
